Firstly great work, this is looking really good. Only real issue in facing concerns audio. When I play music, it will play for a few seconds then drop, this is constant and happens on all music players.
Any clues as to what is wrong?
Lrthumwood First read here https://forum.dudu-auto.com/d/14-how-to-give-correct-feedback-on-bugs
Without your system version and other details nobody would be able to help you.
I think team has to collect the log and try to fix all of issue. May be team needs to revisit the core system bluetooth pair logic.
블루투스 전화에서 벨소리 파일의 음량을 조정하거나 벨소리를 변경하는 방법이 있나요?
Hello, are any of these software updates is compatible with MEKEDE DUDU7 2K ? Thank you
krysmitch57
https://forum.dudu-auto.com/d/410-duduos-dudu7-global-241008-update
You're asking in the 7862 update post. The link I gave is for Dudu7.
wwest2 Thank you
Hello I have a serious problem with the Sim card in my dudu7, everything looks good, it shows that the sim card is connected, the antenna too, the setting is correct, I can't get any connection with data, data currently works only with Wi-Fi, do you have any advice. Besides,### I would like to find the password for Developer options. Thank you
krysmitch57
Regarding the password, please check the link.
https://forum.dudu-auto.com/d/110-faqcasto-zadavaemye-voprosy/3
krysmitch57 you must contact the sim company and they will give you the settings for APN, i had the same problem
Hi. I ordered DUDU7 and so far everything works except for the internet, what I found is that the IMEI number does not exist in the system, it is not registered and, no phone company can give me a SIM card for this DUDU7,Thank you for your advice, besides the settings for APN also requires a registered IMEI. Does anyone have any good advice on how to register the IMEI number, and who should do it? Thank you.
And Password system is : Reset Password: 3368 - Developer Setting Password :7870
krysmitch57 No need to make double posts. I have never heard about this situation. Please wait for an answer from the devs. In my Dudu I have a Lebara SIM card and it worked from the start. I have another friend that has DUDU. He uses another provider and also no problems. A bit more details like your country and the providers that you tried with Dudu would help a lot. Please make sure you have the correct APN settings. Normally you would find them on every GSM providers website.
Hello, thanks for your answer, I am from Canada, and here we have Rogers Telecommunication, and Bell Telecommunication, also some smaller companies subordinate to these two, if you go to check the IMEI number, it can not be found in the system, and they start the SIM card activation and APN from there. in Europe it may look a bit different.
krysmitch57 check what bands the isp uses vs what bands come with dudu. It's an issue in usa
I have a question - does Dudu7 have any protection against theft, for example a series number or some other option, is there some kind of website or something to register it?
krysmitch57
What about "Google find my device"? The most simple one.
And if you had the possibility to register it in China and it gets stolen in the Netherlands, USA, Spain, Poland, etcetera.
What are the chances you think you will ever get it back.
Better use "Google find my device", or one of the paid services.
Hi, I would like to join the beta testers for a generic 7862, how can I do that? @YAOXILONG
thank you
romedo
FAQ/Часто задаваемые вопросы
Read here. Use the built in translation toll or Google translate
Do this global version support dongfeng aeolus huge hybrid car and please if you can show me or send me the steps to uninstall the Chinese version of dudu launcher installed on my car with this thanks in advance dear
