Popescu dudu-lai I record the video and i noticed another issue. Trouble with diffrence of 2 degrees The information in the "trip info" menu is intermittently displayed https://www.transfernow.net/dl/20250630ZjbPS9Ob https://www.transfernow.net/dl/20250630BrJGBL34
Popescu And i noticed on screensaver it don't appears 3d car. I don't know of is a problem or this is the image. Thanks.
dudu-lai https://drive.google.com/drive/folders/1g4ZD9gSC-SK-xywMbgG5IWYi7Y9t9j9j?usp=sharing Hello, the temperature problem has been fixed, please install the 3 APKs in the link
dudu-lai https://drive.google.com/file/d/19U0WpHJiY3C217QZNYdZKIM9SCZ7Pzv9/view?usp=sharing 3D car does not display, please install the APK in the link
Popescu I have Install the apk's, the 3 model car is solved, the diffrence temperature is the same 2 degrees. I restarted head unit 2 times. Thanks! With the information on trip info appear/desepaer is any solution?
dudu-lai Popescu Temperature issue not resolved? Try again using this air conditioning interface and turning on this setting. Itinerary issue is being analyzed
dudu-lai Popescu Hi, I have uploaded a new APK, after installing it please set the temperature difference to -4. This APK also fixes the trip issue, please try it! https://drive.google.com/file/d/1M7KT8DeDGsMdAyXsbFtxGnRpkaQ3VzgS/view?usp=sharing
dudu-lai Popescu Please refer to this thread for feedback methods and provide us with error logs. https://forum.dudu-auto.com/d/14-how-to-give-correct-feedback-on-bugs
Popescu dudu-lai I Install apk, ac work whitout problem, the only issue is with trip info. Is the same problem, appear and disapear. Thank you for your support and patience. https://www.transfernow.net/dl/20250701sz9cg86z
Popescu dudu-lai Hi! Today appear error. I made a video if helps. Thanks https://www.transfernow.net/dl/20250702nhxclMGC
Popescu I've also observed that the day/night mode (or theme) doesn't switch automatically with the headlights. It seems the unit isn't detecting when the car's lights are on. On version 3.5 was working.
dudu-lai Popescu Sorry, I'm on vacation for two days. Brother, please provide the version information of DUDU, I want to confirm whether the apk I provided is installed successfully.
dudu-lai Popescu https://drive.google.com/file/d/14rLVjAnCHX5nJ_ywc2GRErLqkNmJrhx4/view?usp=sharing New software, if the problem is not solved after installing APK Canbuslog txt file is required
