Janebo DUDU-Meng I was changing region to North America and reregister my account, but still the same error,
Janebo DUDU-Meng Hi, I have found the reason for this fault, I had to change from Norwegian language to English in the Android setting, then the account staying connected, But why is there not possible to have my applications in Norwegian?,
DUDU-Meng Janebo Please try installing the latest desktop app manually. If that doesn't work, you can switch the service area to North America and try again.
Janebo DUDU-Meng Hi, I was installing the app, I see this is a newer version, but the fault with account connect and disconnect is still there when language is set to Norwegian in the Android setting, it only stay connected if the language is set to English
Popescu Janebo Hi, i confirm the same problem. I have language Romanian, if is selected romanian the account is disconnected, if i select English stay conncted. I have the Dudu 7 with last update, but it was the same on previous update.
Popescu DUDU-Meng Hi, i switch to North american service, is the same thing, when i select romanian language the account is disconnected. When i select English is ok, stay connected.
Janebo DUDU-Meng Hi yes I have tried the North America service area, still the same error when trying to use Norwegian language,
MoonRaider Hi, i have the same issue. Im in Portugal and my account is always connecting/ disconnecting.
DUDU-Meng Janebo Popescu JhonnyD MoonRaider Bruno This issue has been fixed. Please install the latest desktop app to test this issue. Thank you. https://drive.google.com/open?id=1o1Dgi8SeCFNCir4SWV_EBplr4WazQ3Nz&usp=drive_fs
JhonnyD Same issue, Germany. Question, do you have 4G card installed. I think when using WLAN from home, it stays connected.
Popescu DUDU-Meng Hello! I confirm, i change language to romanian and the account stay connected. Thank you.
