reg66 jweber018 I can't recall exactly as it was some time ago I updated the Bt firmware, but I think I remember mine being stuck too. I think when it was pending I hit either pause or cancel and then had the option to continue (or words to that effect). After continuing it downloaded and installed fine
jweber018 reg66 thanks for the reply reg66! In my system there does not appear to be an option to either pause or cancel. It just shows the "Download" option and when I tap it, it never starts.
reg66 jweber018 Oh ok. I'm fairly certain I had a similar issue. What happens if you click the 'pending' sign/icon? Are you able to send a screenshot? Maybe that'll jog my memory
DUDU-Meng Rangerranj The call function of Android Auto still requires Bluetooth communication. Are your Android Auto and Bluetooth connected at the same time? If both are connected, please check whether the phone switch is turned on in the Bluetooth pairing settings on your phone.
DUDU-Meng valik4767 Bluetooth firmware update to fix Bluetooth music connection issues. Please update and try again. cq134-s2-dudu6-v22-20250612.7z1MB
jweber018 DUDU-Meng could you please share the firmware update for DUDU7? My unit won't download the update via the OTA app
DUDU-Meng RogerF DUDU4 does not have Qualcomm 3031 Bluetooth mode and does not support separate Bluetooth firmware upgrades.
DUDU-Meng jweber018 https://drive.google.com/file/d/1ewTCAMLNY99HeJtK7yr0bZ0sq3z2IwMA/view?usp=drivesdk
jweber018 DUDU-Meng sorry, I might have not been clear with the request, is this the bluetooth firmware update? or the complete DuduOS update?
jweber018 DUDU-Meng meng, sorry for insisting, I think you sent me the MCU update, not te BT Firmware update. Also when I try to install it, it gets stuck at "installing, please wait".
DUDU-Meng Duglas17 To compare machine models, unzip to a USB flash drive. When inserted, it will automatically detect and upgrade.
