As I mentioned before connecting to different Wifi 5g and 2.4G networks works fine, but connecting to iPhone hotspot doesnt work.
Cannot connect to IPhone hotspot
Look at the IP address of the iphone hotspot.
Then set up a static IP to link to the hotspot and try it
I've tried to connect with static IP, it showed "connected" for a second and keep recconecting again and again, even with "Auto-reconnect" off. Check this video. I've tried to connect other devices to my iphone hotspot with the same settings, and they all connecting fine.
I'm trying to reproduce this for you, but we have an iphone X max here that has no problem turning on the hotspot, and the DUDU7 can connect successfully!
Help grab a YLOG. Let's analyze the problem.
YLOG crawling method
I’m experiencing the same issue. Iphone 15 hotspot works great, xs max will not obtain IP
DUDU-Meng Here is my ylog and anr while i was trying to connect. Ylog, Anr, Spec
https://drive.google.com/file/d/1gygpTOjvSmxzDrQvpoQBk1p7K7WQwjD3/view?usp=sharing
https://drive.google.com/file/d/1C2RY16V39FunO4ZTHs8lyW-n1OpxuIIZ/view?usp=sharing
https://drive.google.com/file/d/1P3zPLlPBzIHGWCLP1pv6cjMEuPWIQIjm/view?usp=sharing
@DUDU-Meng any progress on this one using my Log files above?
I'm sorry. There are no results yet.
Please be patient.
Cannot connect to iphone hotspot, please update this system to test if it can solve the problem.
Specialized test iphone hotspot can not connect also problem, without this problem please do not update.
https://drive.google.com/file/d/1wSuA77D_uRjIulqC1O2inX90_4p3Ggd2/view?usp=drivesdk
Fix the problem of not connecting to iphone hotspot
DUDU-Meng I've updated Dudu with update that you've provided, i also reset iphone network settings and tried different settings, but issue is exactly the same as before. Its keep connecting and disconnecting and after couple of times just showing IP configuration failure. https://youtu.be/Fus06yk0AAc
Okay, I'll resend a new system later, and I'd like to test it again, please.****
