Cannot connect to iphone hotspot, please update this system to test if it can solve the problem.
Specialized test iphone hotspot can not connect also problem, without this problem please do not update.
https://drive.google.com/file/d/1wSuA77D_uRjIulqC1O2inX90_4p3Ggd2/view?usp=drivesdk
Cannot connect to IPhone hotspot
Fix the problem of not connecting to iphone hotspot
DUDU-Meng I've updated Dudu with update that you've provided, i also reset iphone network settings and tried different settings, but issue is exactly the same as before. Its keep connecting and disconnecting and after couple of times just showing IP configuration failure. https://youtu.be/Fus06yk0AAc
Okay, I'll resend a new system later, and I'd like to test it again, please.****
Newly compiled system , please help to test if this problem can be solved. If it doesn't solve the problem, please help to catch YLOG with this system.
Thank you for your help.
https://drive.google.com/file/d/14Sn9IMyh7Qziy7xv4g9G54GhL_PSC0Uk/view?usp=sharing
DUDU-Meng Tried new system with phone reset and all possible settings change, still the same outcome and exactly the same issue with IP address. Here is YLOG and SCREEN: https://drive.google.com/file/d/1Nsl21GmSo51T_FtU2lhJmey5-yJVBu0X/view?usp=sharing
INFO: INFO
Thanks for the logs. Let's keep analyzing.
Recompiled the new system, please help test it for the iphone hotspot issue.
https://drive.google.com/file/d/1iO0vhIihsYYvUEFPrq2oFoX4RtLb3iJz/view?usp=sharing
Hi I am having the same issue on my unit. How do i apply this update?
swedespeed Download the last test system firmware I posted and run the upgrade with U Test it out
DUDU-Meng Issue stays exactly the same. Here I've prepared 2 videos, one is using Static Ip address connecting on android, and second using regular DCHP.
https://youtu.be/GIzETSp85Eg
https://youtu.be/dpI5hlVvN0g
Something just keep disconnecting that hotspot, and test showing that its not an "Auto-reconnect" feature.
Click here to download the file
Please update this script and help test it.
If it still doesn't work, could you please grab the LOG again?
Thank you, sir.
Just curious if you have tried this with a DIFFERENT iphone?
Okay, let's analyze it again.
