• Update Bulletin
  • DUDUOS 3.5 Pre-Release: Experience the Revolutionary Upgrade! (2024/12/17)
acvdmolen Google Assistant basically works but there are bugs such as GMaps starting in full screen not in PIP then. The bug is still present in v3.5 RC 241211, I had reported it for v3.5 beta 241118 (https://forum.dudu-auto.com/d/630-google-assistant-gmaps-pip-error). If I remember correctly, the bug was not present in the stable version 241008 so my hope is that it will be fixed for the next stable version.
    gismo okay but it won,t work as designed at this moment because default is gmaps but there is not an option to exchange gmaps for another navi app suchs as TomTom Go wich is very populair in Europe. Also no action when i want to call one of my contacts or want to play a list from my Spotify or use internet radio through Tunein app.
    Regards,
    Arjen
      acvdmolen For the music it works great with YT music. I can confirm it doesn't work with making phone calls. And also that you cannot select a Navi app working only with GMaps. I think if we have a bit of patience the developer team would implement both.
      It's not a launcher
      After running a radio app among the apps
      Music stops when running multimedia
      have an error
        Hi I installed the latest update and on my radio dudu7 on the music widget and on the N.A. bar below I cannot click on thenarrosmtomget the music playing to advance like I did on last version. Also accessibility needs to be turned on for apps almost every time. In the last update it handled this better. Also really really need more than two music apps in the music widget. If that is done this would be a much better radio. Also if I have tidel playing and hit the split screen button it will switch to the app I have in the music widget thus turning off my tidal music.
          Sadly this did not work for me. My Dudu7 said that this version does not work on my device.
          When can we expect the OTA Update? Looking forward to it.
          YAOXILONG changed the title to DUDUOS 3.5 Pre-Release: Experience the Revolutionary Upgrade! (2024/12/17) .
          Still no love for Nissan x-trail/qashqai canbus features. :-(
          Por favor alguien me puede mandar un tutorial de como instalar la actualización 3.5 limpia (borrando todo) por favor espero su ayuda ya que actualize al 3.5 y no me funciona los datos moviles
          • ozzy replied to this.
            Pedro13 copias los archivos de la carpeta Factory Reset a la raiz de tu usb
            Salve, ho aggiunto un sintonizzatore radio FM in entrata aux del Dudu 7, posso finalmente sentire la radio con il sistema di ricerca automatica della frequenza AF. Due giorni fa ho installato il nuovo firmware DUDUOS 3.5, ma ho riscontrato un problema! Mi spiego ; la musica in entrata aux si sente ma quando metto la schermata principale o apro altre finestre si interrompe la musica e per poter sentire la radio devo aprire di nuovo ma non posso cambiare la schermata , vorrei tornare alla versioni precedenti ma non so come fare , aspetto qualche consiglio grazie.
            MihaiFlorin
            Buenas , hay una manera de hacer dongroader a mi dudu7 ya que con la nueva actualizacion3.5 no me funciona datos móviles ... la maquina lo reconoce pero no le da internet. Soy de PERU
            The usb screen mirroring option is gone, now you don't want it?
              Добрый день. После обновления 17.12.2024 года стали происходить челчки по динамикам когда нажимаешь плей на музыкальном плеере. Подключено через звуковой процессор герц dsp h8. Стоит 24/48. На Октябрьской прошивке челчков не было.
