  • Best OBDII?
JhonnyD I've tried 3 different ones, 2 that show up as OBDII and none of the 3 work with DUDU
    9 days later
    tsbrewers tsbrewers Is the PIN to pair 0000 on these IBD2 devices ?
    By default, Dudu will use 0000 aas the pairing PIN. If it is something different - you need to change the BT Phone pairing code to 1234 or whatever it is.
    a month later
    gismo and yet my newly purchased vLinker MC+ wont connect to my DuDu 7 Head unit. I have a collection of 5 now and none work.
      johnyfalco it's even officially supported now (v3.6 release). Mine connects fine, either in the devices settings or in the Android BT settings of my Dudu7. On older DuduOS versions, only the Android BT settings worked.
      johnyfalco What's more, Vgate iCar Pro 2S also works on the vLinker MC+ setting. At first it had problems reading fuel level or coolant temperature, but after a few starts everything works regularly. Connecting to OBD is very easy. Can you show how you try to connect OBD to DuduOS?
      Вам необходимо в пункте BT Phone поменять пароль на тот который требует ваш адаптер.
      Затем в пункте OBD выбрать ELM 327, и ниже выбрать адаптер.
      Важно. Адаптер не должен быть сопряжён, ни с чем. Ни с андройдом ни с DUDU в меню BT.
      После чего у меня начали отображаться все значения.
      Получилось просто случайно. я тоже пытался его принудительно сопрячь.
