  • Best OBDII?
My vGate vLinker MC+ had no problems getting paired via Android BT settings and I can use it on DUDU7 just the same way I used it on my previous FYT7862 unit: Mainly an app to monitor the DPF (VAGDPF) and secondly Carscanner. I have not tried to use it with the internal DUDU7 OBD stuff because i) I'm concerned that it would interfere with the above apps (I always need to disconnect one to use the other so afraid that DUDU just blocks other apps) and ii) DUDU7's OBD functionality seems rather basic (generic OBDII rather than car specific protocols) so not sure as regards benefit - fuel consumption etc is available in the car anyway. If DUDU7 could read/interpret the status of VW group DPFs incl. regeneration and gear box / clutch temperatures then I would sunset the other apps 😉
    I got the KUULAA OBDII. It is connected to the DUDU OS, but there is no data showing in the status bar or in vehicle information app. I test it with a third party app, and it works fine.
    My car is 2007 Toyota Camry Hybrid.
    Head unit 13” FYT.
    OS DUDU 7862 V240927.
    Kindly, if someone has a solution for this issue please share it.
      ahmedjassm I have Corolla Hybrid and the only data that I get is cooling liquid temp and battery (12v) voltage.
        MihaiFlorin
        I am getting the battery voltage even without the OBDII.
        I think it is measured by the head unit, not sure.
        MihaiFlorin
        I got VEEPEAK OBDII, it is works perfectly with Dr. Prius and Hybrid Assistance apps. But it doesn’t connect to DUDU OS.
        I just want to share this with you in case you want to try these apps.
          ahmedjassm I have Vgate vLinker Mc+. Same situation. It works perfect with Dr. Prius and Hybrid Assistant but I can't make it work with Dudu.
            @"ahmedjassm"#p2796Yes. The host itself can obtain the voltage.
            MihaiFlorin Because foreign OBD may be different from our domestic products, this needs to be matched according to the equipment. Tomorrow I will ask the developer if I can get some samples to match.
              dudu-langzi
              That will be greatly appreciate!
              dudu-langzi I already provided a sample of vLinker MC+ to your team. But the devs said to have patience because it is not on the priority list at the moment.
              2 months later
              Is there any news on this topic? use the vlinker ms!
              15 days later
              I need a new OBD2. Mine is an old slow BT2 model.
              Will OBDLink SX be supported anytime soon?
              Should I wait for development, or order one of the adapters recommended in Telegram channel?
              18 days later
              Can you share the list of adapters listed on Telegram please? I would like to buy one that definitely works!
                Can you make this work for the XTOOL A20pro? I think it requires password protected pairing which would be good to have for security. I was also wondering if odb with usb-c cable could work.
                  Chubaka885
                  I mentioned earlier that I have 3 OBD dongles and none of them worked.
                  I just saw the list on Telegram and one of my OBD dongles is that Noname one.
                  It did work on my Mekede 500S, but not on my dudu7. Not via the settings, as it should be done, and neither when trying to directly couple it in Bluetooth.
                  I guess it is a hit and miss. How many "confirmed Noname working" reports are there?
                  Edit: yaoxilong advised me then to try with Bluetooth= 0 instead of 7. It didn' t make any difference.
                    • Edited
                    surfer63 в Телеграм я оставляю ссылки на проверенные варианты на основании ответов от пользователей. Т.е. прям на подтверждение пользователя. К сожелению, я не могу сам проверить работоспособность каждого из них.
                    Определенно есть проблемы с работой OBD в лаунчере. И команде DUDUAUTO нужно над этим поработать. Мы уже сообщали им об этом.
                    BasTijs For security, simply chose OBD-adapters with a physical pairing button (OBDLink, vLinker MC+, etc.)
                      gismo For these OBDs with physical pairing button, do you know of which one that works with duduos?
                        pvtri96 Not yet but vLinker MC+ seems closest as Duduauto have been provided with one for testing.
                        I've been using one with my former radio and continuing to use it with Dudu7. It pairs fine and works with the apps I need (Carscanner, VAG-DPF, etc.) just not yet with the internal DuduOS functionality but that's not so important to me as it's too basic anyway. For instance I need to look at clutch temps when doing certain off-road tracks...
