sleis In my universe if there is a problem i cant fix i would help within my knowledge to address (find the right person or company) and find the deeper level.
dudu-lai sleis Contact the CANBUS box company to collect panel button information on the same car, and write the data into the CANBUS box, so that DUDU will take effect
hafiz_tahir dudu-lai may know will we able to contact raise directly to ask for the implementation? Or need to be fron DUDU engineer?
sleis benzol It seems you have a uncommon brand can box, no idea where to find. If i was you i would lookup a common brand can bus box like raise, they have detailed public information available on their web page (for example szraise.com)
hafiz_tahir dudu-lai may i know where you find this doc? I want to check the supported signal for my canbus box (raise)
dudu-lai hafiz_tahir Sorry, Raise does not disclose information about Proton cars. You need to contact Raise to obtain it. I am just a porter, copying some public information of CANBUS box.
hafiz_tahir dudu-lai ya, i try to browse their website for the documentation, also not available. I will try writing to them to ask about it. Want to know what data available.
dudu-lai sleis The Raise engineer I contacted finally responded. He recommended using the G-RZ-GM61 model. The wiring harness you're using needs to have CGI cables.
sleis dudu-lai Do you know which sales channel i should/could use to order the raise G-RZ-GM61 Can bus box?
sleis Is there more info to the G-RZ-GM61 Box? I found one but the other information on the box shows me same software version (SW:V001.41) and nearly the same hardware (HW:GM-GD7L-0A01 date 250927) so maybe i just could update my 51 box to a 61 box?
