DUDU-Meng Connecting the OBD through the DUDUOS Device menu does not work with third-party applications like "Torque Pro" that I am using... For this I need to connect my OBD adapter through the default Android Bluetooth settings menu. Then it works correctly with Torque.
I use some custom PIDs that I have entered by hand in Torque Pro for proprietary DPF parameters for my car. I am not sure that I can see advanced parameters through DUDU OS. If I am wrong, I would be grateful to you if you could tell me how I could do it.
Also, there is another bug related to Bluetooth of DUDU OS. If I have my phone paired and then I pair my OBD adapter through the Setting > External Devices > OBD Menu, then I can see only the name of the OBD adapter as connected. The phone is connected but there is no name for it in the bluetooth menu. Even if the OBD adapter is not connected the next time I start the car, and only my phone is connected to DUDU7, in the settings it writes that the current connected device is the OBD adapter. So the name of my phone has been replaced by the name of the adapter... Then if I delete the OBD pairing, it deletes also my phone pairing and I need to pair my phone again and then it's name is displayed correctly. But if I pair again the OBD adapter after that the name of the phone is dissapeared and replaced by the name of the OBD adapter. You need to fix this bug for the next update of DUDU OS...
