Mikescotland Thanks for your quick reply Mike!
The setup is fairly basic. I have a Dudu7 that is in my Mercedes Vito W639 through an ISO radio block. In the front I have a set of upgraded Hertz speakers and and in the back some Pioneers. All on the standard wiring. Nothing special tbh.
I have thought about an amp/dsp that I would connect to the spdif out from the Dudu7 and connect the speakers to that amp. But the Amp versions that you place between the Dudu7 and the stock wiring is a very easy to integrate option. Would be great if there was such a solution but with a bit better quality.
I did just try the "All audio resets" I'm the dudu7 and there I found a setting that limits the volume level system wide. I have set this to a higher setting and the audio does seem to be louder now. So that's a good step up. But some real better audio would be even better š
