qwertykolea dudu-lai Hello, thank you for your advise. Could you recomend another CANBUS for my car Kia K7 (K700) Hybrid, 2016(from Korean market)?
qwertykolea dudu-lai Yes, I've seen it, but which one exactly. I've googled and find out that raise rz-12; raise rz-13; raise rz-14; works generaly on Kia cars, but I'm not sure what is the best for Kia K7 (K700) Hybrid, 2016.
dudu-lai qwertykolea Please take a photo of the connector on the back of the OEM mainframe and I will check with a Raise engineer!
dudu-lai Dude, are you still online? Is it convenient for you to select that option and try to adjust the volume, are there any latency issues?
qwertykolea dudu-lai Hi, yes I've tried this configuration too. Result almost the same as with Sonata9 - 2016.HIGH.AMP, but sound a little bit worse. Also I'm attaching photos of my original maineframe.
qwertykolea Hello @dudu-lai , Photos that I've attached in previos port is it enough for asking raise engineers about apropriate canbus for my car?
dudu-lai qwertykolea I consulted with Raise engineers and he recommended RZ-HYK-13 and RZ-HYK-14 (AMP)
qwertykolea dudu-lai Hi, I bought another canbus (RZ-HYK-13 and RZ-HYK-14 (AMP)) as you recommended, but noise sound became even louder. In this link: https://we.tl/t-QIH6tRRKxV you will find: URecorder_25062025_151637.m4a - noise sample that I recorded video_2025-06-25_16-15-52.mp4 - how I turn on the canbus logs and choose my car (KIA K7) from the list log_2025-06-25_0.txt - canbus logs
dudu-lai qwertykolea Please try it. If the noise disappears after unplugging the audio RCA, you do not need the RZ-HYK-14 (AMP) box, and connect the original car coaxial audio directly to the coaxial interface of DUDU
qwertykolea solved dudu-lai Hello, I succesufully solved it, as you said and with instructions from your telegram: RZC: https://t.me/duduauto/15845/258919 HY-SS-04: https://t.me/duduauto/15845/258922 Denny7 FYI
Denny7 Was this issue ever resolved. I've had the same issue with a kia soul with the simple soft can.
