  • Steering wheel learning button problem
Didn't see what you meant by that.
Is it the volume that doesn't work, please?
    Do the numbers jump when studying? Are there hints when studying for completion?
      DUDU-Meng
      DUDU-Meng volume up, volume down previous and next buttons. In general whatever i have in the circle is not working. Is not making even studying.
      dudu-lai sometimes it was doing like that now im general is not even recognizing whatever i have in the circle on the photo.
      Are you sure that buttons are not working via canbus?
      If it is you can't learn them.
      You just have to set correct canbus in settings.
      I connect my cables exactly how it was before but it wasn't working anything. When i try to make the learning procedure the most of the buttons they was working except of volume up/down and next /previous buttons. Doesn't matter how many times i reset my SWC and i make the procedure again and again still that specific buttons they are not working and not even recognize them.
      Do they work with oem radio unit? Maybe buttons broke.
        Gwinambele Yes they was working perfectly until i remove headunit
        Do you have the keys wired through the canbox or to key1?
          DUDU-Meng my car doesn't have canbox and i was thinking if that is the issue
            xarishewii
            That's a wiring issue, there are two steering wheel button learning wires.
            You wire it up and you can set the buttons in the settings
            You wire it up and you can set the buttons in the setup.
            Just connect one of the KEY1/2 wires.
              DUDU-Meng But on the car wiring it's 3 cables
              One it's ground and another 2 data cables 100% from dudu i connect both key1 and key2 to each of this cables
                xarishewii How the cables are connected, please take pictures
