• Update Bulletin
  • Exciting News: DUDUOS 3.6 Beta3 Public Test Version Release! 250328
anpandiyaraj
DUDU radio has two bluetooth modules, the name of the external independent module is DUDUAUTO, and the name of the motherboard integrated bluetooth is FYT_Android.
DODO OS bluetooth can only use external bluetooth to connect to cell phone for bluetooth phone call and bluetooth music.
If you modify it yourself to use bluetooth_type=0 then all the problems created cannot be handled.
And it must have a lot of problems
The name of the Bluetooth connection to the phone is DUDUAUTO.
Possible for the ADAS system you the 360 camera?
Arielnac This option only appears now and is closely related to dudu os. In all applications there is a day/night switch and using this switch we can influence what theme is currently on. This solution is better, people who start with dudu os do not have problems with this option that was previously available in android settings. For me it was a duplicate option, in dudu settings it would be enough.
    Sorry for posting this here, I'm so in love with dudu os. I made myself a wallpaper for my smartwatch.
    wybitny2 Самое неприятное, что яркость привязали к режимам день/ночь. Установить полностью темный фон и сохранить автоматическую регулировку яркости по свету авто сейчас невозможно. Это очень плохо.
      It is just posdible with root and the spp DarQ, at the moment
      Hello I have Opel mokka x 2017 and I Chevrolet with ac controll app and information vehicle.my canbus it’s rcz
      wybitny2 I agree with that. But that duplicate control in the Android menu is on a higher level than the duduOS menu. So it allows me to have the backlight automatically change with the time of day, even if the day/night mode in duduOS is set manually. This means that I can have absolutely all duduOS menus without a white background. And as I mentioned, I don't like having any screen with a white background, either during the day or at night. For example, if you want to change an equalizer setting, during the day, it appears with a white background.
      Hello, can you support Beidou satellite? I can't find any available Beidou satellites on Amap.
        • Edited
        nonon DUDU5/6 Only the Chinese OS version can use Beidou.
        DUDU7 supports all mainstream satellite positioning in any country and region
        liamstears Everyone has this problem. The app is somehow related to the launcher and there is a preinstalled version from Dudu Appstore unfortunately, there you can update it, but in Google Play Store it is still listed. I tried to uninstall it via ADB, but then the launcher did not work properly, it was almost impossible to do anything on the screen, the touch went crazy. It would be nice if the devs took care of this, because it is quite an annoying bug.
        Maybe with root and Lucky Patcher
          JhonnyD As I wrote earlier, the GPStest application is related to the launcher, so the package would have to be completely removed from the system, uninstalling via ADB without root does not help, because the package still exists in the system and you still can't install GPStest from the Google Play Store. The only way is for the devs to fix it in the system itself, apparently the preinstalled version is not the same as the one from the Google Play Store, or modified for system use, it's hard for me to say. Howeber, i have no idea, whether in the case of root, removing the application and installing it from the GP Store will ensure the correct operation of the Dudu launcher. Maybe someone has tried and could comment on this issue? @DUDU-Meng @dudu-lai maybe know something?
            • Edited
            Nein. Mit Lucky Patcher kann man die gleiche App mit unterschiedlichen Signaturen drüber installieren
              JhonnyD yes, but you have to root system, you can't install untill the app is in the system. Anyway LP is risky, not everyone knows, how to use it.
              Slavus The Gpstest app does conflict with the system's built-in apps. It's not very easy to fix it yet.
