• Update Bulletin
  • Exciting News: DUDUOS 3.6 Beta3 Public Test Version Release! 250328
Gwinambele I would try to overcome any personal concerns you may have with the word "beta" and instead embrace the new version and complete the update. The UI is WAY better!! Plus, you will continue to help the dudu team if you do encounter any random bugs, and they test thoroughly all versions before release, of course.
@Arielnac - you may find your answers here and here
YAOXILONG Can we have controlled call pip show flag(ro.syu.callpipshow=1) ?
For example when android auto/apple carplay connected don't show the call pip show window. Show only when Android auto/Apple carplay not connected. Is it possible?
Bring carlink app to live/active/front when call is received and window is in background.
There is a problem with tts google voices. In android radio they are quiet, the switch to increase the volume of speech after the update of the google tts application does not work. There was a problem before, but it was sporadic enough that it was possible to live with it. Now, when I turn on the switch, after downloading the sygic application, the switch to increase the volume of speech stops working. I would like to point out that I do not download the google tts application update, after downloading the switch does not work. Radio dudu7, dudu os 3.6 beta3. Of course, for software tests I always do a factory reset, although it is not required. I also noticed that the Google TTS application has a bug, in the newer updates the increase TTS voices switch from Google does not work. If we have a phone the situation is the same. The switch only works in the application that is installed after installing the software, only that the TTS voices in the phone can be heard well and it does not affect the fact that in the new TTS updates the switch does not work.
Benruba2025 Is the auto-connect switch in carlink 2.0 already on?
Mi pantalla es de 9,5" y tras instalar la última beta, se puede comprobar que el tamaño de la fuente pudiera ser muy grande y no se ve entera, aparece recortada
    Benruba2025 It will be fixed in future updates. Problem is known. This happened because of the font changing.
    Buenos dias, se que se ha comentado ya, pero si tras instalar esta version, y no quisiera mantenerla hasta que salga la version definitiva, ¿ como podria volver a la version 3.5?
      Benruba2025 My friend, it is clearly specified that the beta version may contain errors.
      YAOXILONG 📢 Important Notes for Beta Testers:
      👨‍💻 This beta version is designed for enthusiasts who are eager to try out the latest features and provide valuable feedback. Please keep in mind that beta software may contain bugs, instabilities, or incomplete translations. For regular users, we recommend waiting for the official release via OTA update.
      But from what I see, nobody has the patience to read anything around here, not only your case.
        MihaiFlorin It is software, every version will have something. Unless you think Dudu 3.5 release was 100% error free.
        What version of Windows OS is "error" free?
        MihaiFlorin lo he leído, y su propio nombre lo indica, es una versión Beta, entiendo que pueda contener errores ( no suelo instalar versiones beta) pero DUDU7 me ha parecido tan bueno, que si no me gusta, poder volver a la versión 3.5 y esperar a la definitiva versión de 3.6.
        Gracias por su apreciación
        DUDU-Meng But surely this is a step backwards? Having more options for users is better than less options for users right? I personally would like and use this feature if it was available...
          I went back to version 21-01-25 because in beta 3 they removed this option from the on-screen menu. With this option, I could choose manual theme selection in the launcher to manually select the night theme as the default theme, and in the on-screen menu, I could set the backlighting to be managed according to the time of day. In beta 3, I was unable to get it to work this way, and during daylight hours, I was left with a blank white background in the launcher menus.
            YAOXILONG Could you please help me with android auto connect issue? step to reproduce
            1. first connect to android auto (use any method)
              2 after connecting android auto disable bluetooth and wifi in phone. also close carlink app in headunit.
            2. wait for minute and just enable bluetooth in the phone and don't select any bluetooth device.(I am using samsung s23)
              Bluetooth never getting paired with headunit. Even headunit never try to connect to paired device.
              I am expecting headunit to request connection when paired device is near by. (There might be these setting disabled in phone to battery saving. i don't want to touch phone setting).
            Arielnac It's good that they removed it, my friends had problems with these switches. I don't deny it though.
              YAOXILONG 1. Need service for:
              • Monitor Bluetooth connection/disconnection events
              • Periodically check for disconnected paired devices
              • Attempt to reconnect when devices are disconnected
              anpandiyaraj I am guessing its something like the persist.lsec.enable_a2dp=false setting that can fix this? How do I apply this? Also this seems to make a lot of changes and I don't want to upset anything else, can I just change this setting that I need? How can I get the current settings from the unit so that I can revert if need be?
                seems to be working well love the ui fixes
