• Update Bulletin
  • Exciting News: DUDUOS 3.6 Beta3 Public Test Version Release! 250328
JhonnyD As I wrote earlier, the GPStest application is related to the launcher, so the package would have to be completely removed from the system, uninstalling via ADB without root does not help, because the package still exists in the system and you still can't install GPStest from the Google Play Store. The only way is for the devs to fix it in the system itself, apparently the preinstalled version is not the same as the one from the Google Play Store, or modified for system use, it's hard for me to say. Howeber, i have no idea, whether in the case of root, removing the application and installing it from the GP Store will ensure the correct operation of the Dudu launcher. Maybe someone has tried and could comment on this issue? @DUDU-Meng @dudu-lai maybe know something?
    • Edited
    Nein. Mit Lucky Patcher kann man die gleiche App mit unterschiedlichen Signaturen drüber installieren
      JhonnyD yes, but you have to root system, you can't install untill the app is in the system. Anyway LP is risky, not everyone knows, how to use it.
      Slavus The Gpstest app does conflict with the system's built-in apps. It's not very easy to fix it yet.
      yoshi The local directory has a duduos_carsh folder.
      See if there are any log files generated in there, and if so, please send them to us!
        Hello
        How can i activate or get the ADAS Widget for the 2K ADAS Camera ?
          liamstears keep specific setting alone in config.txt and flash with help of lsec6315update
          Cabrioman External device inside Connect the ADAS recorder.
          Desktop ADAS plug-in Click on the 3 dots Settings Enable ADAS
          YAOXILONG unmarked the discussion as super sticky.
          yoshi Local storage/duduos_crash
          Look here to see if the error file is generated
