dudu-lai DUDU reversing camera connection tutorial https://wiki.dudu-auto.com/en/installation/reverse-camera You also need to switch to reverse camera mode in the settings
dudu-lai Tarek Please take a picture of the connectors on the back of the original main unit and on the back of the monitor to confirm that you have received the right cable.
Tarek It's update or somthing for the canbus or it's wiring issue Because as I mentioned the door status ( open or Close) not appearing on the screen The screen not dimming when turn on the headlight
dudu-lai This connector contains the CANBUS cable, if the original host does not have this connector, there is no CANBUS cable (and therefore no door information,).
Tarek ok, is it possible to connect the CAN-L & CAN-H wires from the canbus to the ODB port to get this information
maxingato Tarek Where you able to connect this? Do you need to to conect them to the canbus adapter? i want to do same but I will be tapping the CAN lines from the Body Control Unit (BCM)
Tarek Hi, This is the dudu AHD 1080P camera, as you can see the resolution is really bad. is there setting to be configure?
wwest2 Tarek Set the radar as right or left of the rear view in the vehicle setting and see how it looks. I think this is because the video was stretched to be shown in full screen.
Tarek dudu-lai Somehow, the rear view camera image size changed I don't know. how to get the full screen again. before Now
