Opel Insignia Center console not working
Same model CANbus adapter in my Meriva B. I had an issue where the 8 pin CANbus plug had not clipped into the socket of the Dudu7 (completely my fault) and it worked it's way loose during installation. The display would intermittently show the doors open and the fan controls being used but volume control and the SWC buttons were unreliable. After fixing the connector securely it all works well.
TL : DR: Check: Settings->About->Model name. If the text string ends Unknown CANbus version double check the 8 pin CANbus plug.
Bury I currently have the same CAN decoder, but with SW version: V0009, and now it plays the turn signal sounds through the built-in speaker. With the previous CAN decoder, I had to connect an additional speaker for the turn signals, and there was a constant central locking error (red door with a key icon) that would disappear when the turn signal was activated, but it would come back shortly after. And just like our friend UK_Matt already mentioned, double-check all the wiring connections and make sure everything is properly secured. You might also try disconnecting the car battery for an hour.
I have the sister model of this car and Simplesoft (XP) GM-SS-04 or Hiworld works the best!
@dudu-lai If we want to add canbus functionality, do we it via DUDU OS or do we need to contact canbus manufacturers? I have some canbus commands for some features/buttons not supported by any manufacturers
Amazinjoey
I have the same one ,GM-SS-04. is there a way to change buttons mapping ?
Amazinjoey Need to contact CANBUS supplier
any idea why yesterday it was working and today it doesn't ?
