  • v3.6 Canbus Bug: Skip fwd rwd now is the same
I couldn't downgrade, sadly - see https://forum.dudu-auto.com/d/876-duduos-36-beta-released-just-in-time-for-chinese-new-year/94
So I've done more testing:
  • The error affects VW PQ and same gen (Polo before 2019, Golf6, etc)
  • Error does not affect MQB and same gen (Golf 7 etc). When I select those, Skip works fine. But then I loose door status, PDC etc as my T6 is PQ.
@dudu-lai appreciate your thoughts. Everything worked fine in v3.5 for VW PQ and now it's broken. And I can't downgrade without factory reset apparently.
I can confirm I have this same bug for VW PQ, I hope dudu engineers can fix this asap...
OS version 3.6 is not an official version and will be updated in the future. the CANBUS service is different at each date and will have to wait for an update in a subsequent version.
Temporary solution: Downgrade back to OS3.5 or update the CANBUS service separately.
6 days later
已经修好了https://drive.google.com/drive/folders/1RPDCr0jORbXREQde1DQksHSa8stqRlE-?usp=drive_link
    dudu-lai
    This link needs access granted to be able to access it, can you share it freely instead?
      dudu-lai
      This fix works perfectly, Thank you
      16 days later
      dudu-lai on 3.6 beta2 cannot be installed.
        Slavus 3.6 beta2 Is this still an issue?
          DUDU-Meng Yes, it is. The file shared on this thread cannot be installed because of "App not installed as package conflicts with an existing package."
          It's because the version number of the installation file is lower than the one built into the system.
          The system does not allow downgrading the installation
            DUDU-Meng Yes, i know that. Issue is still present.
            dudu-lai
            This worked for beta 1 but the issue is still in beta 2, can we get a fix for beta 2?
              liamstears Just confirmed that the official version of the service already includes this fix. Just wait for the next system.
                DUDU-Meng
                Thank you, do we know when this might be?
                  liamstears It should be in the near future.
                  12 days later
                  Fixed in 3.6 beta3👍
