  • CarPlay problem
Anyone?
Can be connected to carplay via USB C
    dudu-lai I believe his question was asking if usb-c will charge faster then regular usb
    dudu-lai
    So if i connect my phone here CarPlay will work by wired?
    4 days later
    dudu-lai Can be connected to carplay via USB C
    @Wass You have your answer here. Please read the above posts.
    @Wass
    Also: your phone will not charge faster on USB-C than on USB-A. Both are very low outputs.
    Buy a 12V usb-hub and insert it between one of your uSB-ports and your phone. That will charge faster.
    Or simply use Carplay wireless and load your phone via a cigarette heater plug (and buy a good one. Cheap ones give a lot of interference and may not load fast either)
      surfer63 Can you please show me a picture or a url for the 12V usb-hub you mentioned because I didn’t know the type you mean
      Is there a way to automatically start Carlink when I turn the ignition on and the unit wakes up from sleep?
      • Tbui replied to this.
        If it is only to load your phone quickly, you can use this
        or this.
        but these are only (fast) loading USB-hubs.
        When it comes to extending/splitting one of the unit USB cables and transmitting data, like for AA or CarPlay, it gets terribly difficult. In that case your need a USB hub with input and output, or a bi-directional USB-hub.
        5 years ago I purchased an USB-hub with one input and two output cables and 12V powered, but I can't find it anymore. I can't find any like those anymore.
        I used that on my PX5, years ago. Now I only use my phone wirelessly and power it via a cigarette heater plug (my 3rd plug as the previous two gave a lot of interference)
        dudulover someone mentioned you can do that via Task. Like iOS Automation.
          Tbui You mean Tasker? Just want to make sure it works before buying it.
          https://tasker.joaoapps.com/
            dudulover
            Like this directly in dudu.
            dudulover Settings/other/task. Set a task there like in the picture above
            10 days later
            dudu-lai I tried more than 100 times actually wired Carplay not working except with the 4 pin port, i tried with the 6 pin the both usb ports but not working , also i tried with the usb c but not working, so i have only to choices, the first one that i use the wireless connection and that is very unstable connection and i can’t use the hotspot , the second choice that i use usb port 4 pin and that is very bad because my phone battery is decreasing because of the very poor charging.
              Wass We tested if the USB C and 4P USB ports could connect to the carplay.
              The charging speed is the same for both ports.
              • Wass replied to this.
                dudu-lai ok i will wait for your testing , also Is there any way to make the charging faster ?
                  Wass Both USB C and 4P USB can be connected to the carplay. the USB output is 5V and 2A, there is no faster way to do this!
                    7 days later
                    dudu-lai That is not correct on my unit (Dudu 7)
                    Only 4 pin usb can connect to CarPlay
                    Usb C will never connect to CarPlay
                      Wass Did you replace the USB-C harness for testing?
