  • CarPlay problem
Wass Did you replace the USB-C harness for testing?
    • Edited
    dudu-lai I used 3 cables i tried with extension also i tried to connect it directly but same no carplay , the same cable i use it with 4 pin it works great , if i connect the usb c plug the phone charge and the hotspot work except the CarPlay
      Wass
      Coming back to your initial question: "I have a problem that if connect my phone via wireless sometimes not connecting and sometimes there a lag, so i try to use USB ....."
      Some releases ago, there were issues with wireless Apple CarPlay connection. These issues are now solved.
      If you first tried wireless, then why don't you go back to wireless?
      Secondly: 6-pin USB only expands on 4-pin USB by adding redundancy.
      What kind of iphone do you have? Iphone 15 and newer have USB-C. older iphones don't. There are issues with iphone cables going from 4-pin or 6-pin USB to the Apple lightning connector as some (cheaper) adapters have removed pin 3, pin 2-3 and or ping 6-7. These cheaper cables give issues with 6-pin USB.
      Please check that.
      That you tested 3 different cables doesn't mean much if they were all the same cheap cable. Please let us know.
        surfer63 I have an iPhone 14 Pro Max and with the factory apple cable, I cannot connect to wired CarPlay(not that I would ever use it with head unit)ether. Not sure why someone would want to use that low res thing anyway
        a month later
        I tried usb c to usb c both 2.0 and 3.x from anker, ugreen, silkland, apple oem cables and none have worked natively from the DUDU7 11.5inch back usb C port. It charges and the carlink app shows the animation when you plug in a usb connection but no car play. No pop up on the iPhone 16 Pro Max as well.
        Now if I try car play using the 4pin to USB A port that comes with the head unit using the same brand of usb A to usb C cables. All work without any issues.
        Thanks.
        • Wass replied to this.
          dudu-lai can you please let me know the exact cable you used for your testing of usb c to usb c car play. I will buy the same one to test
            TheRareElite There is no specific cable, if I have time I'll record a video of it
              dudu-lai that would be great, thank you!
              TheRareElite I did the same i used 4 cables even the original cable that came with the iphone no one work, just believe me the only port which can be use for CarPlay is the 4 pin port, don’t try anything because it will not work I tried everything.
