2013 Hyundai Genesis, American model. Dudu7-12-256GB-9.5.
The temperature pop-up only changes temperature when I have my vehicle programed in Celsius. When I switch to Fahrenheit. The temperature stays on 63F.
I can switch my temperature from Fahrenheit to Celsius by holding down the Mode and Dual button for 4secs.
I have tried to upload pictures and video to this post with no success. I have also tried just one picture.
How do I attach a video and pictures to a post?
I get notice, "Upload max file size limit reached from php.ini."
AC Display Only Changes Temperature When Set to Celsius
2013 Hyundai Genesis, American model. Installed Dudu7, 12-256gb-9.5
To LSDUDULAI. I use Whatsapp. Would I be able to communicate with you using Whatsapp?
I started seeking technical help using your Installation Discussion. I was instructed to switch to this forum and share pictures and video. I'm unable to share pictures or video in this forum.
Brief summary of problem. The floating Air Conditioning only shows a change in temperature when in Celsius. When I switch to Fahrenheit. It only shows 63F at all times.
Under Can bus settings for the OD-HY-21 Can bus type. I only see the Hyundai Tucson listed. It does not work.
I been using the Can bus Raise setting. With the Raise setting, I have the Rohens model listed. But I do not have the American model Genesis, which uses Fahrenheit.
Once again I tried to upload one picture and I get the same red notice, "max file size reached".
Pegasus91
Why can't you upload pictures?
Every user can do that. There is the media button below in the "edit" bar. You upload photos and select the photo you want to use in your post. Screenshots made on the unit work fine. Photos from my camera (16MP) work fine as well.
I believe that videos might be too big to upload.
@dudu-lai The fact that AC stays on 63F has been mentioned earlier in the forum as well as in the telegram groups.
See here for the forum post: https://forum.dudu-auto.com/d/776-2013-hyundai-genesis
Edit: there is also this post: https://forum.dudu-auto.com/d/410-duduos-dudu7-global-241008-update/24
surfer63 We have paid attention to this matter and need to analyze the reasons.
surfer63 The two post you shared, do not provide a solution to my air conditioning situation.
As why I haven't been able to post a video or pictures. I don't have an answer. I will continue to try.
dudu-lai I use Whatsapp. Would I be able to communicate with you using Whatsapp?
dudu-lai Sir, I downloaded Telegram and sent you pictures and a video. Any help you can provide. I would be grateful.
Did you ever get an answer to your problem?
