[1] Describe in detail the error you encountered.
Trying to use the tilt/roll widget but it forgets a calibration within a couple of minutes.
This is before calibration:
This is directly after calibration:
And this is 2mins later - car was not moved at all:
I had not unpowered or rebooted the radio in between. I don't understand why this drifts all the time.
[2] Provide a screenshot of the system information and take a picture of the system information in the pop-up window by long-pressing on the top-left image for 3 seconds in “Car Settings”-“About”.
[3] Is it possible to reproduce the error and what are the steps to reproduce the error?
Yes, 100%. Just calibrate and then watch it drifting or jumping. Keep radio powered up (after power cycle I would understand that the calibration is lost due to gyroscope having to come up again).
  • Edited
I can confirm the problem with the gyroscope.
Never had those problems with Mekede, Teyes or this cheap Iying UIS7870.
The software currently has this bug
It may be fixed in the future
    • Edited
    DUDU-Meng it's a valuable function for offroad use - and campers (to level the car on uneven ground). But it should work. My DUDU7 is installed in an offroad campervan 😉
    11 days later
    Stasis is valid
    Deviation will occur when the vehicle is moving
      DUDU-Meng is this an update? Car was not moved at all in my case (in the two mins between calibration and last picture)...
