Black6spdZ Was this bug resolved? Also have duduauto steering wheel controller with a brand new battery that is not found on my 9.5" 8/128 unit.. I thought it was supposed to just work!
dudu-lai Black6spdZ Can you search for devices with the name ylfk on your phone? https://wiki.dudu-auto.com/en/%E5%A4%96%E8%AE%BE%E9%93%BE%E6%8E%A5/%E8%93%9D%E7%89%99%E6%96%B9%E6%8E%A7
Black6spdZ Phone doesn't see anything either.. No literature explains how to put the damn thing into pairing mode.. Isn't this standard BT connectivity 101?!
Black6spdZ found the problem.. a simple one but without ANY documentation it's an easy one to make. The battery was in upside down! I didn't realize it until I finally ran across a post where someone with the same initial problem made note and actually showed a photo of the correct orientation. I double checked the box that the controller came in and besides the fancy cloth bag NO PAPAER instructions at all!..
dudu-lai Black6spdZ After correctly loading the batteries, long press the round button, the indicator will light up
dragonflytsu When I install the battery the indicator light blinks once and then goes off. If I long press the center button nothing happens. It doesn't show up on the head units bluetooth list when I search for devices. I have the 8 core 4x64 for a 2017 RAM. Any help would be appreciated.
dudu-lai dragonflytsu Can the Bluetooth connection of the mobile phone be searched for the Bluetooth named ylfk?
Duff I just got the DUDU SWC a similar problem. After inserting a new battery correctly, the LED flashes a few time. I am able to connect to the YLFK signal, but thats it. The controller does not connect. What am I doing wrong?
Duff I am connecting via the BT SWC. The iPhone is also connected. Can the DUDU manage 2 connections ?
