  • Dudu7 no usb
Denny7 I meant on the 2k dvr the red light comes on but no connection.
  • Edited
Denny7 какое подключение вы ждёте от телефона. Это не компьютер. Подключение телефона как накопителя не будет. Вы пробовали вставить usb flash drive?
    Chubaka885 yes format it and tried usb drive no connection
    It was recognized by enabling external storage write permission in the developer options settings.
      lockc ok i will give it try Thanks!
      lockc no luck on that one thanks
      Could you please show a picture from the back of the plugs?
        JhonnyD usb plugs?
        Sorry, i meant the back of the head unit 😊
          Ok will send after work
          JhonnyD
          Looks like the two usb plugs are not pressed deep enough into the port.
          Sometimes those plugs feels like they are plugged well but look at it.
          11 days later
          dudu-lai yes sir there is 5 volts. Still no usb or won't recognized dudu 2k dvr. The red light is on but no connection. PLEASE HELP!
            Denny7
            What kind of harness is this, you should use a USB cable with blue plugs
              dudu-lai i tried a different one because the usb don't work on the blue ones was just testing.
                Denny7 Can you try using the blue 4P plug cable?
                I've never had it charge, but not read the flash drive!
                  Ich bin noch immer der Meinung, dass die Stecker nicht richtig sitzen.
                  Ich habe es mehrfach gehabt, dass die nicht richtig saßen und man glaubt es ist ok.
                  Ich habe dann die Sicherung gedrückt und den Stecker weiter rein gedrückt.
                  Dann ging es.
                  Kann ja sein, dass es in Deinem Fall auch so ist.
                  Grüße
                    JhonnyD I did push them in hard but no luck. It's do not show any isb options.
                    dudu-lai yes sir i tried all plugs.
                      Denny7 Contact sales for after-sales service
