Hello,
I’m a BYD Atto 3 owner from Thailand, and I’ve installed the Dudu Launcher from dudu-lucky.com in my car.
I have a few questions I hope you can help with:
1. Is the Dudu Launcher developed by the same team as the one here?
2. What are the main differences between Dudu Launcher and DuduOS?
3. Is it possible to install DuduOS on my BYD Atto 3?
Thank you!
DUDUOS 3.5 Release: Experience the Revolutionary Upgrade! (2024/12/22)
Noragarnz I will try to answer your questions
- Yes
- The differences between launcher and the OS are that the launcher is only an APK, not a full fledged firmware and the launcher does not support all the function/features of the OS
- No. You can install only the BYD version of the launcher.
For dudu OS3.5..the volume now does not show the volume number.
Can make it show?
@YAOXILONG quisiera ser parte de el programa de prueba de DuduOs para UIS8581A
Luchodiaz23 Read the FAQ thread. You'll find your answers there
Am I reading this correctly, that optical and coaxial output up to 24bit/192Khz? So the standard 48Khz Android limitation is bypassed?
Will this work on a yt5760b? Vertical screen?
I recently updated my Dudu7 head unit in my car to the latest OS. I have a problem, on the android interface you could previously set the font size and the screen size at the same time. After the update, the option to adjust the font size remained, but the option to adjust the screen disappeared. As a result, the font size in Waze navigation is very small, I am over 60 years old and cannot see the instructions well, important information is lost on the 10-inch screen. Where can I set the screen size? How can I cancel the update, because this is unacceptable for me.
I tried it, I set the font size to maximum, but the change was minimal. The letters are much larger on my 6.5-inch phone, and Waze is easier to use. In the version before the update, I was perfectly satisfied with the screen size setting option. This is omitted from the new version.
I would like to install this on my 7862 device. How could register my device or activate it for testing?
Rishad Read the FAQ thread.
Скажите пожалуйста. Почему у меня после обновления от 22.12.2024 года при нажатии на кнопку плей происходит щелчок по динамикам. В Октябрьской прошивке такого не было. Помогите.
Bonjour,
J'ai installé la mise à jour 221224 et je rencontre un problème avec la navigation maps sur mon HU 7862.
Maps affiche l'itinéraire (la voix annonce l'orientation) mais pas la flèche de de navigation, quelqu'un a-t-il eu ce problème ?
Hellow moderators.
I just recently buy FYT7870.
Can i install dudu os on my unit?
wolf-jr No. DUDU OS (firmware) works only on DUDU devices. Not general FYT 7870. There is no beta testing for 7870.
Here it was measured again. Is a very good German forum with sound enthusiasts;
https://www.klangfuzzis.de/threads/dudu7-android-headunit-mit-android-13-und-uis7870.107953/
Every time I try the OTA update it downloads successfully then has an error when trying to update. Then the unit goes into a recovery mode for 500 seconds and nothing can be done until the time is up.
Почему разработчики молчат обращаюсь неоднократно. У меня после обновления от 22.13.2024 года стали появляться щелчок по динамикам при нажатии на кнопку плей на музыкальном плеере на штатном. Так же и на стороннем приложении. Подключено все по оптическому кабелю через звуковой процессор герц далее через усилитель и на динамики. На Октябрьской прошивке щелчок не было.
I purchased the Melede M7 Pro direct from Mekede. It didn’t seem to have the DUDUOS installed so I went ahead and followed the instructions to install the DUDUOS 3.5.
Installed Global_DUDU7870_2412221316_2412031108.7z.
However now there is a bar saying “ui and mcu does not match unit”. What can I do to fix this?
19712809 Maybe you need to do a factory reset and see what happens. In the phone, when the new version comes out, a factory reset is recommended. There is no newer version of Android here, but I still think it is advisable. I had some errors in dudu6 related to the radio and resetting to factory made the errors go away.
where can I send error log files? Is there an email for the entire programming team?
yesterday installed without problems OTA..3.5...
Я бы попросил разработчиков dudu сделать и переднюю и заднюю камеру с более большим разрешением. Сейчас изображение какое-то расплывчатое. У тиайса камера намного лучше.
I installed Duduos 3.5 on 7862 FYT, but my Ac theme is not updated to Dudu one, its still showing the older one from my old FYT OS, any help?
I just did ota update to my new dudu7, but now it shows update error and rebooting...
is there a way to change the DPI/resolution of the Apps? Some apps are very tiny in the minimalstic mode.
Hi i installed dudu OS 3.5 but everything is upside down, how to i rotate the screen?
Talha0 Please be a little bit more specific. You installed Dudu OS 3.5. In what type of device? Dudu device? General FYT device? I would recommend you to get on the Telegram group. More than sure somebody there will help you.
