  • dudu7 having problems with CarPlay and AndroidAuto
Have the same problem...
    MihaiFlorin
      BenAriel Try to update to the latest version. Available here on forum. And see if the things get better. You have 241008 version and the latest is 241217. You are more than few versions behind the latest one.
        BenAriel
        you have to connecti via wifi (carlink... network), beside bluetooth
          obelix80 you mean the hotspot ?
          its turning on by it self when you open the app
            MihaiFlorin I tried,
            I connected the HU to wifi and then I searched for updates and nothing no new updates were found
            also when I download bluetooth update after it finished it says flash in
              BenAriel
              in my case sometimes did not connect by it self, it look to conecting eternaly...
                BenAriel
                obelix80 yeah same thats what happend in the first time and then when I close the app and open again its connecting in the second time
                obelix80 I kind of find a solution but its annoying one
                before you get in the app you need to turn on hotspot manual and then get in the app and it will connect the first time I hope they will fix it
                  BenAriel Man. Have you at least tried to read what I've said? I have said to update to the latest firmware available. Dudu OS firmware, not bluetooth update or something like that Please try to read the first page of this forum and also the FAQ. Use the built in translation tool for the FAQ. If your unit doesn't find an update, this doesn't mean that there are no updates. Even if those updates are beta ones.
                    MihaiFlorin I searched for a firmware update it didn't find any
                    MihaiFlorin how ? its says I have the latest one
                      17 days later
                      I'm having the same issue. I believe mine is the latest update. I attached a photo. I'm not sure which one the version number I'm not the best with technology. Any advice would be appreciated
                        moaz3019 yeah did the last update and Carplay working much better but android auto still got issues
                          BenAriel
                          Please describe your issues. Even if it is a repetition of previous mentioned issues. Nobody knows what to do with unknown issues.
                          And what do you consider the latest update? The image from @moaz3019 is NOT the latest update. If you refer to that version, you should upgrade to 241224. If you refer to the 241224 (and not 241222) version, then do mention that.
                          Or did you install a newer Carlink version from some place, and if so: do mention that version as well.
                          I am on dudu7 241224 and I have tested Android Auto inside a PIP window now for 4 days wirelessly and did not run into one single issue. Immediate connection, navigation, Google assistant, audio, phone calls: Everything worked perfectly.
                          So please describe your issues.
                          And when using Android Auto or CarPlay: do not switch on the hotspot on your phone.
                          Update: I was wrong. The 1224 is a beta version. The 1222 is still the public version. I am sorry.
                            surfer63 Where do I find 241224 version?
                              You can do an OTA upgrade on your device.
                              Or you can download it from the links in removed
                              Update: I was wrong. The 1224 is a beta version. The 1222 is still the public release version. I am sorry.
