• Update Bulletin
  • DUDUOS weekly update newsletter!240916
MihaiFlorin
Indeed. The option in the menu showed up after installing the DuduAuto Pro update. Unfortunately it's of no use for the car I'm using the unit in. Too old 2009 Audi TTS.
For those not seeing the option, enable the Beta App Access as mentioned before and install the DuduAuto Pro from the unit's Appstore
    YAOXILONG unmarked the discussion as super sticky.
    suicidalguitar
    Did all that but there is still no detail vehicles showing. That's all I can see. Beta testing app is on and Dudu Auto pro is installed.
    I can't upload pictures now but both I the app Vehicle Details
    and in the settings under vehicle I can't see those extra features.
      HondaCivicDriver
      I can't see them either. I assumed that's because the car/canbus does not support it. But now that I'm thinking a bit more about it, it doesn't make much sense. It should show that screen anyway, even if without any values.
      I'll take a look into's @MihaiFlorin tip.
        suicidalguitar Make a photo of your about device details. @HondaCivicDriver And a photo of what you see. If the option is enabled and you cannot see nothing on that screen is because your canbus is not supported. The devs are working on implementing more vehicles. But it won't work on every vehicle. More details are always good. Like car, manufacturing year, canbus type and a photo about your device details.
          I could enable the option as shown above. 108 is the necessary password for factory settings.
          My bad I overlooked it before.
          But yes, it's also depending on the model and can bus support, so I can't control my AC and neither do I see any car positioning information with angles and so on.
            MihaiFlorin , sorry for the delay.
            Whenever I try to open the Vehicle Details app, it opens the Vehicle Settings app. With one difference. When opening Vehicle Details it looks like it wants to open something else with the DUDU logo. But that's for like a fraction of a second. Then it open what you can see in the 2nd screenshot.
              suicidalguitar It depends on he canbus decoder and the type of the car you have. Before it would have said vehicle not supported. But now it opens the old "vehicle info"
                MihaiFlorin Just as I imagined. It's a 2009 Audi TTS.
                It's not an issue anyway. Just one of those things that's fun to have but not essencia
                Thanks for your feedback
                MihaiFlorin postei as fotos para voce ver como está configurado. O Spotify fica abrindo mesmo quanso você fecha ele.
                  Carlos- How can I know that only from the pictures? I think you posted the pictures on the wrong post. I saw your other post. What exactly is your problem? Do you want Spotify to automatically play music or what? Be more specific my friend. Otherwise even if I want to help I can't.
                  Estou tentando dizer que ele está com este problema de ficar abrindo sozinho mesmo você fechando ele. Exemplo estou na tela inicial do rádio e ele volta abrir.
                    Carlos- try the telegram group. I don't have such problems with YT music. Delete all the tasks in the tasks settings. Long press to delete. From what I see in the pictures you have a task to open Spotify set there.
                    Vou testar, ele automatiza o Spotify?
                    Carlos- and please every time when you report a problem provide a screenshot or photo of your "about device" info.
                    Carlos- and please be more specific about your problem. The translation doesn't do a very good thing. If possible try to communicate in English.
                    Carlos- You don't have to be sorry. You must understand that if you want help you must provide as much info as you can. But nobody can help if you just post some pictures and you don't describe nothing.
                    Hi guys,
                    Anyone has this issue? I get no statistics in vehicke settings related to fuel consumption, will upload photo later after edit.
                      Christian_S The type of car and canbus decoder would help a lot. Are you from Romania? Can you leave here your telegram?
                      24 days later
                      Vw Jetta 1.6 tdi 2014, rzc-raize canbus decoder./Dudu 6 on 7862.
                      Thank you
