sleis I changed the UART Pin from 16 to 14 and tested all three busses. I can not find any differences. The behaviour is the same
sleis Is it not possible to deactivate most of the button assignment? If i could just use it for the volume knob (which is working) i am already much further. I could integrate all the rest with standard non canbus signals also the swc is already prepared to be used over key1/2 wires ...
sleis Maybe you could help me to understand the chinese way to solve my problem. How would you start to solve? Who do you think is responsible? Or would you just state it impossible and give up? Thanks so much for your help up to this point and much more thanks if you could let me participate a little in chinese methodology ...
sleis In my universe if there is a problem i cant fix i would help within my knowledge to address (find the right person or company) and find the deeper level.
dudu-lai sleis Contact the CANBUS box company to collect panel button information on the same car, and write the data into the CANBUS box, so that DUDU will take effect
hafiz_tahir dudu-lai may know will we able to contact raise directly to ask for the implementation? Or need to be fron DUDU engineer?
sleis benzol It seems you have a uncommon brand can box, no idea where to find. If i was you i would lookup a common brand can bus box like raise, they have detailed public information available on their web page (for example szraise.com)
hafiz_tahir dudu-lai may i know where you find this doc? I want to check the supported signal for my canbus box (raise)
dudu-lai hafiz_tahir Sorry, Raise does not disclose information about Proton cars. You need to contact Raise to obtain it. I am just a porter, copying some public information of CANBUS box.
hafiz_tahir dudu-lai ya, i try to browse their website for the documentation, also not available. I will try writing to them to ask about it. Want to know what data available.
dudu-lai sleis The Raise engineer I contacted finally responded. He recommended using the G-RZ-GM61 model. The wiring harness you're using needs to have CGI cables.
sleis dudu-lai Do you know which sales channel i should/could use to order the raise G-RZ-GM61 Can bus box?
