DUDU-Meng for me absolutely not. Contrast is very weak, and all is with "fog". Also, still lights bleeds around and disturbs, as the brightness of the screen isn't lowered, it's just a grey overlay.
For right side steering wheel cars like mine, also when this mode is active, looking from driver side at angle screen has a pink tint (9.5 inch) that is not visible if you look from left angle onto the screen.
Someone said in 3.5 it was possible to turn the brightness to 0 (literally black) and worked as supposed. I can't, driver adjustment stops at 10 and cannot get any lower. Perhaps display driver was altered between the versions? My screen does not flicker or flash when even at 10 in the PWM screen settings.
I've just done over 3000 km partially in the night and had to turn off the screen as on country roads even with that extreme dark overlay light bleeding from screen was distracting ( my settings min 10 in advanced brightness driver settings and 0 for night brightness settings). Too bright!
Besides, when this settings is buried in the menu, when it's just gets dark (sunset) and ILLUM kicks in, you don't see anything, so it's digging in the menu to turn it off and then in the night digging again to turn it on.
