dudu-lai I99 Go to Vehicle Information > Vehicle Identification > Password 3368 > Select Category 2. After setting this, turn off the engine and lock the car for 10 minutes. Then try to see if the mileage display issue is resolved.
I99 dudu-lai The mileage is still blinking the buttons on the steering wheel still dont work neither does the airco …
dudu-lai I99 Connect to the OEM head unit and test if these functions are working properly. If they are working properly, your CANBUS box is faulty.
I99 dudu-lai If it’s broken what’s the solution then Or where can I order the correct and new Cambus and wil that just work ?
dudu-lai I99 Search for Jeep Android Radio Power Cable on AliExpress and ask the seller if it is compatible with your car.
dudu-lai I99 If you follow my instructions and search, you can buy a new CANBUS box. I'm not sure if your CANBUS box is broken, but I can tell you how to verify it. Test it with the OEM head unit.
dudu-lai The OEM host doesn't work, so there's one troubleshooting method missing. Buy a new CANBUS box and try again.
