Kolo457 dudu-lai I would like to mention about animation on the screen which is freezing even when sensors are switched off but animation still is on the screen and block using other app, workaround is to close animation manually by clicking "X" but it's so annoying. Can we repair it before is happens randomly not every time.
dudu-lai Kolo457 The CANBUS box will send sensor data, so it will always be displayed. This is normal.
Kolo457 dudu-lai that was an example, but even if sensor doesn't send any data to radio (car shows on the screen).
Kolo457 dudu-lai video below: https://streamable.com/50q09c I ment that when I am getting out from garage and starting driving sensors are switched off automatically (because of speed limit) but animation is still on the screen (not dessaper after switching off sensors).
Kolo457 dudu-lai as I wrote already it not gonna disappear after 5 sec, sometimes it does sometimes not, and even when I switch off engine and switch on again (even on next day) animation is still on the screen untill I click "X" on the screen.
dudu-lai Kolo457 I helped you solve the Raise problem before, so why do you still want to use XP's CANBUS? Try updating to the latest system.
dudu-lai Kolo457 Sorry, I have absolutely no idea how to fix this. The information you provided is so confusing. Raise and Simple. Have you decided which one to go with? Which one is best for your car?
Kolo457 dudu-lai I have Raise and that CAN BUS works correctly with other functions (like voice command etc) with Simple can bus animation shows the same like with Raise, so issue is with radio not Can bus.
