Zaid DUDU-Meng I think i might need some help, i don't want to open a new discussion in this but let me explain what happened. I tried to downgrade to OS 3.5 global version (I was on Chinese version) now my device is stuck with screen that it requires activation. any idea what to do?
DUDU-Meng Zaid Just choose your region, if you choose China, the activation reminder will pop up, because the channel is different!
Zaid im in china, i bought the device through JD, after the downgrade i selected English and there were no other settings for region.
DUDU-Meng Zaid Did you buy from the domestic or foreign channel in China? Contact customer service first
Zaid i don't know what you mean by that, but for me this is the only english forum that i was able to find and now im seeking for support if possible. I added you on telegram we can talk if needed.
DUDU-Meng Zaid Does the activation prompt appear after downgrading? How did you downgrade? Did you use an overseas system?
DUDU-Meng Ian Please install this app to test FaceTime calls. https://drive.google.com/open?id=1FfN-4HVfAY_1XaX6YSjKv8Cro7TIgqcZ&usp=drive_fs
Ian DUDU-Meng thank you, I will hopefully be able to try that tomorrow - I’ll let you know if it works 👍🏼
Ian DUDU-Meng sorry for the delayed reply. I have just tried it connected wirelessly, and unfortunately it has the same fault.
z95141414 DUDU-Meng I have tested both wired and wireless connections, but there is no sound reception. The microphone of other apps works normally, only FaceTime does not work
DUDU-Meng Ian z95141414 To fix the issue where the other party cannot hear you during FaceTime calls, please manually upgrade this firmware and test it. https://drive.google.com/file/d/1mqlfw743hRavfjYF6HOAUNsKRa-stWIv/view?usp=sharing
z95141414 DUDU-Meng Is there a Chinese version? I'm using S3. Or is there a way to convert it to the Global version? I'm in Taiwan. I need Google Assistant to wake up (hey Google)
z95141414 DUDU-Meng DUDU-Meng I mean the carplay facetime microphone fixed, you only provide the global version firmware
