DUDU-Meng Ian Please install this app to test FaceTime calls. https://drive.google.com/open?id=1FfN-4HVfAY_1XaX6YSjKv8Cro7TIgqcZ&usp=drive_fs
Ian DUDU-Meng thank you, I will hopefully be able to try that tomorrow - I’ll let you know if it works 👍🏼
Ian DUDU-Meng sorry for the delayed reply. I have just tried it connected wirelessly, and unfortunately it has the same fault.
z95141414 DUDU-Meng I have tested both wired and wireless connections, but there is no sound reception. The microphone of other apps works normally, only FaceTime does not work
DUDU-Meng Ian z95141414 To fix the issue where the other party cannot hear you during FaceTime calls, please manually upgrade this firmware and test it. https://drive.google.com/file/d/1mqlfw743hRavfjYF6HOAUNsKRa-stWIv/view?usp=sharing
z95141414 DUDU-Meng Is there a Chinese version? I'm using S3. Or is there a way to convert it to the Global version? I'm in Taiwan. I need Google Assistant to wake up (hey Google)
z95141414 DUDU-Meng DUDU-Meng I mean the carplay facetime microphone fixed, you only provide the global version firmware
DUDU-Meng z95141414 Can the S3 from the Chinese channel be used in Taiwan? What are your needs? Do you want it built-in?
z95141414 S3 can be used, but the GPS location record of WeChat is wrong (fixed coordinate difference) I hope to use dudu7 global version firmware Native support for Google services
z95141414 DUDU-Meng Complete installation, using S3(7870) google service flash package I'll try again
z95141414 DUDU-Meng I used the Google service package, and then my duduos was reset and the DPI display was wrong. Hey Google still not working What is skipclear.txt used for?
DUDU-Meng z95141414 What I sent you is the incremental upgrade package that can be used with the Chinese version.
DUDU-Meng z95141414 Isn't the language of CarPlay determined by the language of your phone? This is projected from your phone.
