• Bug Feedback
  • How to give correct feedback on bugs
Pedro13 Please wait for an answer for your question. Do not double post. And for anybody to help you, please provide your system details as specified above.
Disculpa. espero
    tengo un dudu7 de 10 pulgadas
    De 8gb de ram y 128 de almacenamiento
    Ahora si me pueden ayudar por favor ya qeu actualize mi radio y desde ahi no funciona cuando activo los datos moviles
    Have you updated before from a USB stick? You must download the Dudu7 version (7z archive)from this forum.
    https://forum.dudu-auto.com/d/652-duduos-35-pre-release-experience-the-revolutionary-upgrade-20241217
    Extract the zip archive to a desktop
    The files from the resulted folder (not the folder, but only the files) must be copied to the root of a FAT32 formatted USB stick. Insert it to unit and you should get a message that an update is available. Extract the USB stick only after the green message with "update succesful,please remove....." appears.
    If you want to do a "clean" flash you must move the files from Factory Reset folder together with the other 4 files:
    6318_1.zip
    DUDU AUTO
    lsec6318update
    readme.txt
    When you open your stick the files should look like this
    If you have these files on your stick it should start a factory reset.
    6318_1.zip
    DUDU AUTO
    lsec6318update
    readme.txt
    Estos 4 archivos donde los encuentro? por favor
    A donde debo moverlos? Disculpa no entiendo
      Disculpa si he entendido ... los archivos de la carpeta FACTORY RESET que se descomprimió los debo sacar afuera de la carpeta ok. (y la carpeta la dejo ai (los archivos los corto y pego afuera de la carpeta o simplemente los copio y pego) ultima ayuda por favor
        Pedro13 You must not move those files. Leave them to the root of the USB stick. In the Factory reset folder you have some files (AllAppUpdateA13.bin, config.txt, updatecfg.txt) you must move these files together with those ones in the root of the USB so at the end it will look as in the picture above. This only if you want factory reset.
        Ojala que esto solucione para que funcione mis datos moviles
        Сегодня установил новую прошивку на dudu 7 от 17.12.2024 года. И выскочила такая проблема когда нажимаешь на кнопку плей на музыкальном плеере то происходит челчок по динамикам Подключено по оптике через звуковой процессор. На Октябрьской прошивке челчков не было.
        Hola , despues de instalar la actualización de diciembre no puedo tener internet en mis datos móviles , ya configure mi APN y llame a mi operador para ver si era mi chip y no todo esta bien ... la RADIO ANDROID reconoce mi chip claro perú ... pero no me ofrece INTERNET.. AYUDA
        Dudu7 car Honda Civic X 2017 EU, no information about mileage and fuel consumption B, no information about instantaneous consumption,
          michal0111 Please provide your system information. https://forum.dudu-auto.com/d/14-how-to-give-correct-feedback-on-bugs
          You posted under exactly this thread but you didn't bothered to read at least the first paragraph. Nobody can help you if you don't provide your system info.
            MihaiFlorin
            Sorry. I am sending a photo of the info about the system.
