I have just installed a dudu7 to a 2011 Audi Q5
The items were all provided by your shop except the frame because you don't do a RHD one for this.
First issue, instructions are limited on this, how do you utilise the original screen? The original system has items you need to be able to access. When I had a unbranded head unit this is also how you use FM.
Next is the parking sensors, the parking sensors are still beeping in the background but are not showing on the screen. I've tried looking through the settings and not found anything that would stop them from working. Parking sensors are front and back.
I've attached a screen shot of the modules I've been provided with. I've selected Raise as the module, is that right? The doors are showing as opening and the air conditioning is also showing on screen.
Thank you for your help
