• Bug Feedback
  • DUDU Launcher
  • Edited
I don't know how to post an image. Can you see it in this link?
https://drive.google.com/file/d/1CtWSEF_TxxlWKI2T4PheP_wFdX6pPZqc/view?usp=drivesdk
https://drive.google.com/file/d/1CvjumR8A0f7_IXeAzTW-iz5eG6knTs-v/view?usp=drivesdk
https://drive.google.com/file/d/1Cwry54o0H2gvJhx1NWdlBUPYkRBMEUmC/view?usp=drivesdk
Received feedback that you are using the December 2024 system firmware.
Also update the latest version to test if this issue has gone away.
Were you able to reproduce the problem? Let us know the results of testing the latest version.
Unable to reproduce the problem
That's strange. I saw other people experiencing the same bug on the Japanese forum. Maybe your system version is different from mine? By the way, I haven't had this problem with any other third-party launchers other than DUDU Launcher.
Yes, the system versions are different.
I'm using a newer version.You can also update to the latest version to test if it's fixed.
That's great, I'd like to try it, is there an explanation somewhere on how to update? Also, after updating the system, can I revert it if I don't like it?
It can be downgraded.
Thanks! Can you tell me how to update to the latest version?
    yoshi Directions are found here. Grab a USB drive and start reading! 🙂
    This link is also a good resource for information.
      picasso1850
      Thank you. I'll give it a try.
      8 days later
      yoshi
      This should be standard with the new UI.
      How did you create that google map drive shortcut.
        Chadles
        PlaySTOREからインストールしたよ!
