Gwinambele
Just to be sure format the card again, and follow these steps, use a different power source such as usb plug for the firmware update (not required but removes the power source being the issue)
2K DVR Firmware Upgrade Steps:
Copy the BIN file to the DVR storage card.
Insert the storage card and power on the DVR, inserting while already powered on will not initiate the update.
Monitor the LED indicator.
-the LED will glow continuously for 1 second
-then flash 4 times
-remain lit for about 1 minute
-flash 4 times again
It will then flash slowly to indicate that the upgrade is complete and has started recording.
Reconnect the DVR to the head unit, launch the 2k DVR App and confirm the firmware version matches the one titled that you downloaded.
It’s recommended to format the memory card directly within the app to delete the firmware update files.
If it does not go through that process, try a smaller storage card, if it’s a cheap card from Ali express, try a branded card.
