  • Rolling back to OS 3.0 for DUDU7?
I have the same question. Is there any way to go back to Dudu OS3.0?
    Slavus
    Can downgrade to 3.0
    Just download the previous system and flash it.
      DUDU-Meng To downgrade is not that simple. They need an lsec-downgrade fro lm the Telegram group. Or better you can upload it here. Ask @YAOXILONG
      • Edited
      @MihaiFlorin @DUDU-Meng @JhonnyD thanks for your replays. I asked wrong question. I know how to downgrade of course, but i would to know, is there any download link for DuduOS3.0?
      I have a firmware from 05.04.2024 and ongoing until the last one
        JhonnyD can you share it for me, please?
          JhonnyD Man, You are great, thanks a lot😎
            Slavus Did it work?
              JhonnyD I haven't had time to check yet. Should be able to do it next week. I'll let you know.
              dudu-lai
              After some testing with DTS off, I'm still getting the same problem where sound stops working.
              When audio stops working native volume control is not responsive -- when pressed (volume up or down) it will show the volume but will not change it.
              Switching to stock CD and radio still works fine, and volume control also goes back to normal. But if I switch back to DUDU at this point audio is still missing. The only way around it I found was to either wait, haven't tried restarting yet but I don't imagine that's helpful.
              But in the past few days it does feel like the audio issue is less frequent than last week?
              Seems like a incompatibility in the software, because the Aircon is not integrated in the UI. Touch assistant works for now, but sometimes I do find I will need to wait awhile before the touch assistant becomes responsive from startup.
              What do you think? Thanks!
                Did you install dudu7 and keep the original host or computer?
                Dudu7 and both can speak?
                  7 days later
                  dudu-lai
                  Hi sorry wasnt paying attention, thanks for the reply.
                  Yep sure, give me some time I'll get that for you in the next few days!
                  DUDU-Meng
                  Hi, i think so. In the car there is the main cd player then connected to the original screen. I think the CD player is the main computer/host, which is kept. Afterall the cd still works if I toggle to it. Thanks!
                  23 days later
                  @dudu-lai @DUDU-Meng
                  Hi sorry, a few days turned into a few weeks.
                  Life got a bit busy and this issue was actually pretty hard to capture, but here it is:
                  [https://drive.google.com/file/d/1xhjynZDrqPhWcAzNnG-Uzz8RCIHI2rZy/view?usp=sharing]
                  In there I've got a readme, have a look it should explain the context better.
                  Appreciate all of the hard work!
