ciubaka When you press down on the app in the apps list/drawer, there’s close button A588 The same A588 string is used in fan settings Those should be separate strings because they mean two different things.
CHR12345 ciubaka Can I assume this is a DUDU7 device? I’m unable to see this setting on the 7862s device
CHR12345 ciubaka the only option I have is in the sound settings (Amplifier/Fan), but I do not see the option you have in your images (assuming it’s the top setting) that is missing on mine.. maybe it’s in the next update
ciubaka CHR12345 I have checked and fan options on the 7862 platform should be in factory settings and strings are differen there I believe
CHR12345 ciubaka thanks I’ll double check, the only setting that used to be in the factory on stock firmware was the amplifier/fan switch, that seems to now be under the sound settings and not in factory.. it may be something new added recently, if you can see it now in factory settings.
Chubaka885 DUDU-HUANG да, в настройках вентилятора нужно установить значение "выключен" а не "закрыть". Вентилятор "включен", "выключен" или "автоматический". Слово "закрыть" не применимо к вентилятору в этом случае.
