  • 2013 Ram 3500 Manual AC Purchase Assistance
Please provide guidance on system/part numbers for my setup and needs. Cameras, tailgate assembly, canbus, USB connect from the front, and all other parts necessary for install and operation are requested in this quote. The system would be installed by professionals, but with no knowledge of your application.
I seek to purchase the Dudu7 9.5 with bezel for manual AC, and other necessary parts for my 2013 RAM 3500 DRW crew cab with 8 foot bed. The original Uconnect 5.0 head unit is currently installed. The truck may be pre-wired for tailgate camera, but no camera is not currently installed. It's the base Tradesman package.
I want to run two (2) live feed cameras, both rear facing. Can your system do this? I do not want 360 cameras or turn signal cameras. Camera 1 would be in the tailgate for reverse. Which of your cameras and tailgate assembly should I order?
For camera 2, I would like to have a rear facing camera that is accessible as a live feed when the truck is moving in forward or reverse. I tow trailers and want more rear visibility without adding 360 degree cameras or turn signal cameras. Camera 2 would be mounted at the rear of the truck bed above the third brake light on a truck topper. The camera would be 6 feet in the air facing rear. The camera needs to be all-weather. For the best resolution, can I use a front-facing camera and reverse the visual orientation? Which camera do I order?
For the headunit, I want your bezel for a custom fit replacement of the Uconnect 5.0 and all necessary parts. I saw the unit on Amazon.
For memory, I don't intend to run memory intensive apps, just Spotify and Google Maps, etc. How much memory should be configured for my use? I also want to run a Google Fi card. Please advise on setup.
What additional information can I provide on my setup and needs? I do want the USB port accessible on the front dash.
What information does the installer need to configure both cameras for live monitoring? Have you learned from customers with my generation of vehicle with setup details that would be helpful to know?
Finally, can I purchase all parts directly from you rather than Amazon? I tried Ali, but U.S. shipments were blocked.
Thank you
Feddy
The system would be installed by professionals, but with no experience with your systems.
This forum is more meant to help each other with questions about "how to do this..", " why is it not working like .." or "I found a bug ..".
Please address your questions about the purchase of a unit with accessories, and what is necessary, to the sales team via one of the the websites.
    surfer63
    Thank you
