Daveenb
You set the device to sleep after turning off the engine, but when you start the vehicle, the device does not recover from sleep and instead restarts?
Is that what you want to express?
Vehicle>Start Set>Head Unit Startup Settings>Head Unit Status after lgnition Off: Sleep
This option needs to be turned on.
There is indeed a problem with this feature now, even if this option is turned on, sometimes the device will fail to sleep.
We will handle this issue.
