  • Modify config.txt of DUDUOS for 7862 - Bluetooth type mod reference
Hello,
Tried this method to update my bloeetooth type, despite having it set to 1 in config.txt, it sticks with set to 0. In flashing script I have seen some comandline with sed that sets bluetooth type=0. Tried to reflash rom, rebuid congi parameters, nothing works. It can sync with my iphone, but I'm not able to connect to obd adapter (which can be seen in bluetooth settings).
Thank you for any advice/solution you may have for me!
20 days later
YAOXILONG Please post a video tutorial
    YAOXILONG The device is connected to OBD via bluetooth, but nothing is visible from Dudu
    JhonnyD Let me see how to enter
    4 days later
    jkl I agree. A nice video tutorial would help a lot.
    So I have a Mekede M6 Pro Plus 360 head unit. I'm testing the latest beta 241118 version today and I get no bluetooth connections to my DUDU SWC bluetooth device. Nor to any OBD2 dongle.
    But I can pair my iphone currently.
    It seems I need to figure out how to apply this script to change my bluetooth type to 0. Hopefully 0 is the correct version for my HU?
    Trying to understand how to make the change but it's not clear. How do I flash the script?
    Just use the config from the M6 firmware and DUDU OS will adapt it
    Oh. Just reading your recommendation now. Thanks for that idea.
    I was able to figure it out with Vitaly's help from the telegram English group.
    I just had to copy that script to a blank USB stick and edit the bluetooth type to 7.
    Then while the head unit was running I just plugged the USB stick into one of the USB ports and it auto runs the script. Just like "using the traditional flashing method." as he said in the first post. Now it makes sense.
    You're not reinstalling the OS from scratch like I thought he meant. Just plugging it in like the original method.
    Once it rebooted my bluetooth stuff all worked. I have my DUDU SWC working now. Thank you!
    Easiest way is, when installing DUDU OS, to put the config file from the original firmware into the DUDU files.
    Or after installation if missed, put the lsec file and the original config file to an usb drive and just install the config file.
    DUDU then adapts it after boot.
    5 months later
    Dudu7 Google's TTS voices are a bit too quiet. Is it possible to increase TTS voices using config.txt? I use Sygic navigation and have minor problems.
      wybitny2 I can't do that yet, but the channel independent adjustment feature might solve your problem later on.
        DUDU-Meng Google TTS app in newer updates does not work the increase TTS voices switch. Now I cannot download TTS voices app updates to make it work. If it was possible to increase TTS voices via config.sys then the problem would not occur. I start the car after a night and I can hear the tts voices from google quietly. I have to go into the tts voices settings, turn off the increase tts voices switch and turn it on then everything starts working.
        2 months later
        I have a FYT 10.4” tesla screen uis7862… I extracted my config.txt… can I mod dudu7 and install on my unit?
          JGuty Try it and let us know
          I installed dudu7862 and it does work on 10.4 screen but resolution size is not right. Some stuff is cut off on the right side of the screen but apps work properly. Anyone know a fix for this?
          USB AUDIO OUTPUT has stopped working.
          Whereas, all other outputs working.
          Kindly help me how do I fix this ?
          My processor amps and all connections working. It's been more than 4days I am stuck with this problem.
