To get the most effective assistance, please provide the following information when posting your question:
- The specific DUDUAUTO product you're installing
2.Your vehicle's make, model, and year、Car Center Control Pictures
3.The current CAN bus model and version in use
4.A clear description of the issue you're facing,Any relevant photos or screenshots that may help illustrate the proble
Hello,
I am installing a 10” Dudu 7 head unit in my 2011 Chevy Silverado 2500HD WT (work truck trim). I managed to get past the fact the GM doesn’t have an ACC wire in the wire harness for the factory head unit. I have the dvr, square steering wheel buttons and gps antenna working well. My problem is that I no longer have any warning chimes, turn signal sounds, etc that were played through the old head unit. From what I’m reading, it’s probably because GM has a “low speed GMLAN serial data wire” in the one body harness. I suspect that it needs to be connected to the CanBus, but I can’t verify if that idea is correct or what wire it should connect to. My guess is C8 for the CanBus wire harness.
