dudu-lai dvsriot Please contact DUDU sales for the reason why the fabric is not available, please use the debugging fabric in the illustration, here is the stitching tutorial please check https://wiki.dudu-auto.com/en/%E5%85%A8%E6%99%AF%E6%95%99%E7%A8%8B/%E6%8B%BC%E6%8E%A5%E6% 95% 99%E7%A8%8B
Greatape Do the side cameras need to be installed on a horizontal surface pointing down (such as on the under side of the wing mirror) ? Or can they be installed on a vertical surface (such as the side panel of the vehicle) ?vertical is better for me but I don't want an issue where it can't calibrate properly and I make a hole for the camera to then need to move the camera
Ghbtunez Greatape horizontal, pointing down. I found a pdf which explains the positioning better for systems that aren’t dudu7…and Im going to calibrate later today. Just got my mat. I believe the want the camera to be 1/3 pointing toward the door and the other 2/3 pointing towards the blind spot.
tabboz81 Ghbtunez That's a bit unfortunate, as I'd also wanted to install them vertical, same as Greatape. I feared that was the case when I noticed the image would have turned out upside down. Would you be able to share that pdf or where to find it? Thanks
