Amin89 Hello, I have difficulty setting Dts sound precise value as soon as I remove my finger it changes value setting. Is there a way to enter it manually without using the finger this also concerns the high pass filter and low pass filter of the filter it is very difficult for precise adjustment ?!
Chubaka885 Amin89 нет, к сожелению такой возможности нет. P.s. зачем вы постоянно копируете инструкцию? Не нужно этого делать, достаточно добавить информацию согласно инструкции.
Amin89 what instruction you talking about ? in fact I would like to refine the settings of my sound but it is complicated for the slide it up or down there is not arrow for up or down ?!
surfer63 I think that a good feature request would be to add a + (plus) and - (minus) button below or below/above every slider. In that case you only have to tap one position a couple of times.
