BigyUU
Hi
The OP hasn’t responded to surfer63’s advice yet, so it might be best for you to follow that guidance so others can assist you more effectively.
First, you have already confirmed, but ensure that your DUDUOS firmware and apps are fully up to date.
Personally, I haven’t encountered this issue with Waze- it works fine for me. However, one key difference is that I don’t use a SIM card. Could the SIM be causing the issue by making the unit register as a phone to Waze?
Have you tried removing the SIM and using an iPhone hotspot instead? If not, give it a try and see if the error persists.
If the error disappears, reinsert the SIM and check if the initial opening with a WiFi connection prevents the issue from returning.
If the problem continues, it may require attention from the developers unless there are additional settings that can be adjusted.
