• Proper units alignement
In many places units are displayed in a wrong way. Especially distance, time and speed.
Please correct the possible values so they will comply with SI (International System of Units).
so for example, speed should be km/h (kilometers per hour) or mph (miles per hour). Because k=kilo, and K= Kelvin (different unit), m=meter and M=mega
The same is with radio frequency. The basic unit is Hz (not hz or HZ) and standard radio unit is MHz (megahertz)
OK, we'll make improvements
24 days later
almost a month and no changes in this subject
do you have those units hard coded or what?
    ciubaka
    Units have been added, switch here
      DUDU-HUANG
      I think you have misread Ciubak’s post.
      The units whilst available, do not have the correct format. Capital letters are used where there should not be.
      MPH should be mph
      KM/H should be km/h
      BAR should be bar
      KPA should be kPa
      PSI should be psi
      Why can't i open images? (make them big)
        JhonnyD К сожалению функции форума пока это не позволяют. Вы можете открыть картинку в новой вкладке а затем увеличить её.
        @YAOXILONG
