  • Tutorial - Cycling through PiP apps in Normal mode using Mode (Home Key)
First: in settings/vehicle/SWC/Mode Key delete any apps showing there. Normally in Mode key you should have Multimedia as app 2. (Delete it by long pressing on it)
Second: in settings/Home/Layout/Home app Icon action select "Loop Large widget"
Third: in settings/Home/Layout/Large widget loop order selection, select the apps/widgets that you want to cycle through.
Sadly cycling/looping through the PiP apps (1,2,3) is available only on 7870. In the case of 7862 processor you can make some shortcuts on the NavBar or on the widgets, depending on your taste so you can quickly change between the PiP apps.
Hope this will help some of you.
Just configured and I dig it, thx for sharing. How do I minimize the main screen now though to get back to wallpaper home screen?
I also see under SWC there is a note that says PIP not supported! Does this need to be updated to better inform functionality to users?
    picasso1850 just realized I can click on the wallpaper widget to get to main screen, duhhhh. 🙂
    Thx again for this tutorial, it was a great addition to my configuration.
    picasso1850 That SWC function is to open any app you want but in full screen with the help of Mode key from the steering wheel.
